Re: 706 PTO apart - sure enough broken pin
Posted by Aces on September 20, 2004 at 05:07:38 from (67.0.37.160):
In Reply to: 706 PTO apart - sure enough broken pin posted by Andy R on September 19, 2004 at 21:03:31:
Andy I would get the right pin from the dealer it is very hadr and must drive in tight or you will redo this all over again, and all that you got out the PTO needs to go in from the bottom, then screw the squair nut on from the top, but you need to reset the pressure the more you screw the nut on the more pressure you get.
Post a Followup
Subject:
