Re: Quick hitch Draw bar
Posted by Hugh MacKay on September 26, 2004 at 09:15:21 from (216.208.58.131):
In Reply to: Quick hitch Draw bar posted by Scotty on September 26, 2004 at 04:46:24:
Scotty: You have been agonizing over this for some time now. Are you refering to Fast Hitch by chance, as your wording this time has tipped me off to thinking so. Is this Fast Hitch an add on to the Farmall C. To operate this hitch your tractor if original, needs a remote valve. The remote valve would be located where pipes from pump enter the touch control system. The control lever for this valve mounts on opposite of throttle lever from the touch control levers, which control the rockshafts on either side of fuel tank. There would need to be plumbing running from the remote valve back under seat to the lift cylinder. If you will respond to this I think someone on here may be able to sort this out for you. I'm not necessarily saying me, as there are guys on here more familiar with C and SC than I. I am certain we can help, just need to know a bit more.
Post a Followup
Subject:
