Re: Is this a C?
Posted by SAm in NS on September 27, 2004 at 09:59:38 from (129.173.133.73):
In Reply to: Is this a C? posted by terryj on September 27, 2004 at 09:43:28:
Your serial number indicates it is probably an early Super C. Is there a 2" gap underneath the gas tank and above the hydraulic unit? Does it have a water pump? If yes these are a couple of indications that it is a Super C. If you look at the top of the block underneath the #1 (front) spark plug there is a small, raised, flat. You will find (if you clean it really well) the engine serial number there. Hope this helps, SAm in NS
Post a Followup
Subject:
