Re: Farmall M with noise in rearend/PTO
Posted by williamf on October 03, 2004 at 04:59:48 from (66.82.9.79):
In Reply to: Farmall M with noise in rearend/PTO posted by hoss on October 02, 2004 at 17:12:48:
I"d suggest take the pump coupler out, see if it stops. If it"s loose it should be easy to take out. Just a couple of cotter pins and slide the collars to the middle, right?
But the part about the pto shaft sounds suspect. You might wind up taking the cover off the rear end.
Wm
Post a Followup
Subject:
