Re: 966 won't move
Posted by K.B.-826 on October 09, 2004 at 20:16:06 from (209.163.30.65):
In Reply to: 966 won't move posted by Frank F on October 09, 2004 at 16:51:15:
Need to know a couple more things first. If your transmission oil pressure light works, is it on when the tractor dosen't move? Did your TA work in both ranges before, and does it make a difference what range you have the lever in now? How's your clutch pedal free travel? Any possibility the clutch is out? Making sure the Speed Transmission (1-2-3-4) is in gear, engine running, try to shift the Range Transmission (HI-LO-R) into gear with the clutch pedal up. If you can get it into gear, then the TA or clutch is at fault, normally it shoud grind like crazy. Fluid level, filter, any other steering or brake problems? Do you have the type of wheels that clamp to the axle, using two nuts on each side of the wheel to hold the clamp tight? It is very common for the nuts to break, causing the clamp to loosen, which allows the axle to spin in the wheel. However, I would think that you would notice that the wheel had moved in toward the platform if this was the problem. Just for the fun of it, start the tractor, put it in gear, and push the brake pedals one at a time. If the tractor moves with one pedal held down, that would indicate a problem in the final drive or loose wheel mounting hardware on the side for which you are holding the pedal
Home
| Forums
Today's Featured Article -
Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
