H farmal weak spark
Posted by Scott's organics on October 23, 2004 at 18:25:33 from (66.103.168.52):
The tractor has been hard to start
lately and floods easily. Now it won't start or even fire at all. The spark looks weak. I put in points. cond,cap and coil a while back. Now I put in new plugs and rechecked the point gap.
I have mag tore apart. The magnets seem strong. The only thing that looks wore are the weights on the inside. I think they advance the timing. The weights pivot on two little shafts and they are quite sloppy. You can see where
they rub on the inside of the housing because they are sloppy. The magneto does make noise when I try to start it. I think it is the weights rubbing.
I don't know if when they are rubbing if it is throwing the timing off. I adusted the timing both ways to see if it would fire. But there is
nothing not even smoke. I haven't checked the compression yet. When it is running it runs smooth. It is getting gas. Can you think of anything to check?
Thanks
Scott
Post a Followup
Subject:
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
