Re: H farmal weak spark
Posted by MagMan on October 23, 2004 at 18:38:19 from (64.12.117.13):
In Reply to: H farmal weak spark posted by Scott's organics on October 23, 2004 at 18:25:33:
That happens with the pawls on the trip mechanism.
I dont beleve thats what your problem is. I would say to check,File,Sand, All conections . Wires In side The coil, The coil cap, The wire that hooks to the points, Check the points only use a file not sand paper. Make sure there at 13 thousands. Then take the coil wire out of the dist cap and hold it about 1/4" away from The screw on the side that the switch wire hooks to and either turn the mag by hand or on the tractor. And see what you have for spark and what color it is. It should be blue or a little yellow will usally work. I have seen bad plug wire and or coil wires do what you are describing also.
Let me know if you need anything else. I have parts and complete mags avalible.
JON
Post a Followup
Subject:
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
