Re: Override clutch for PTO shaft
Posted by Steve W (NY) on October 27, 2004 at 11:47:07 from (24.213.210.222):
In Reply to: Override clutch for PTO shaft posted by JBlavl on October 27, 2004 at 08:30:53:
I use on on my Ford, and it has a roll pin that you drive through the PTO shaft after you remove the grease fittings. Which means you can't take it off. I have seen a type that has a push button, just like a PTO shaft has to make removal easy. I plan to get that kind when this one wears out.
Take Care
Steve
Post a Followup
Subject:
