Re: Override clutch for PTO shaft
Posted by Andy Martin on October 27, 2004 at 13:50:27 from (64.219.39.195):
In Reply to: Re: Override clutch for PTO shaft posted by Steve W (NY) on October 27, 2004 at 11:47:07:
Of course you can take it off, you just get a little greasy. I put one on every fall to brush hog and take it off every spring to mow hay.
I would steer away from the quick disconnect styles, as they are a little longer and will wiggle a little more. I find that the driveline works better the shorter and tighter you can keep it.
Post a Followup
Subject:
