Re: Buying a 1086 Turbo, any quirks I should know
Posted by K.B.-826 on November 02, 2004 at 19:39:26 from (209.163.43.54):
In Reply to: Re: Buying a 1086 Turbo, any quirks I should know posted by Milan on November 02, 2004 at 16:06:21:
I've heard of those kits too, but I do not know what they consist of. Really, if you get yourself a manual and keep the shift linkage, clutch, transmission brake, and dump valve adjusted, they aren't that bad, but still worse than the 26/56/66 series. Getting caught in two gears is a sign of serious wear and misadjustment. It does happen quite a bit on the 86's, so if you notice that the tractor is hard to get in or out of the Range gears- Hi, Lo, and R, get it looked at right away. It happens when shifting from Hi or Lo to reverse. There is so much slop in the linkage that the lever can be moved back to N before disengaging the gear you were in. You move over to R, try to move, notice that the tractor seems bound up, try to shift back to N, but can't, because the Hi/Lo linkage is out of line. If you think this has happened, shut off the engine, as trying to move in two gears will do major damage. To get it unstuck, you need to pry the Hi/Lo linkage under the cab back to N, then do the same for the R linkage. Really got to be familiar with them to be able to identify the linkages under there, which is why it's a very good idea to get suspected problems looked at before it gets that bad. Call the dealer and tell them you want the clutch, dump valve, and transmission brake adjusted before they bring it out, and also have them check over the shift linkage.
Home
| Forums
Today's Featured Article -
Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
