Farmall Tractors Discussion Board
Re: MRear end oil change
Posted by LynMn on November 19, 1999 at 17:04:22 from (216.161.105.92):
In Reply to: MRear end oil change posted by pete-Tex on November 18, 1999 at 20:53:47:
Nope, dont flush. It will wash out the grit thats
in the lube troughs from gear clashing and into
the brgs. Dont forget to drain trans.Its the
small plug up front pointing forward.
Post a Followup
: Re: Re: MRear end oil change
