Re: to bob m and the 10si with diode setup
Posted by Bob M on November 22, 2004 at 11:15:29 from (165.170.128.65):
In Reply to: to bob m and the 10si with diode setup posted by bryan meade on November 22, 2004 at 10:20:25:
Bryan – If I understand your idea I don’t think it will work!! You still need to somehow shut off supply voltage to the #1 alternator terminal when you shut down.
Simply connecting the diode/resistor to the (hot) #2 terminal like you propose will result a small backflow of current into the regulator whenever the alternator is stopped. While it’s not likely to burn out the regulator, it will heat the resistor and will cause a dead battery if allowed to sit for more than a day or two!
Sorry!
Post a Followup
Subject:
Today's Featured Article - Identifying Tractor Noises - by Curtis Von Fange. Listening To Your Tractor : Part 3 - In this series we are continuing to learn the fine art of listening to our tractor in hopes of keeping it running longer. One particularly important facet is to hear and identify the particular noises that our ... [Read Article]
Latest Ad: 1997 cub cadet 7275 compact utility tractor 4wd hydro trans cracked block 3500 [More Ads]
