Farmall Tractors Discussion Board
Re: Re: Super A Charging System
Posted by Bob on November 20, 1999 at 18:22:27 from (207.19.142.127):
In Reply to: Re: Super A Charging System posted by Curt Cooke on November 20, 1999 at 15:48:00:
with engine running disconnect the battery,if it
quits your not charging could be a bad generator
Post a Followup
: Re: Re: Re: Super A Charging System
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
