Farmall Tractors Discussion Board
Re: Super A Charging System
Posted by Curt Cooke on November 20, 1999 at 15:48:00 from (207.75.224.75):
In Reply to: Super A Charging System posted by Stan on November 20, 1999 at 15:34:29:
Stan, start by making a jumper wire. With the tractor running, attach one end of your wire to the F terminal on the generator and the other to a good ground (use the grounded side of the battery)that way you're in a position to read your gauge. If the gauge jumps to the charge side, the problem is with the regulator. If it doesn't, the problem may still be the regulator. If nothing happens, remove the cover from the regulator. With your ground wire still in place, close the contact points on the solonoid that are the hot ones. If the contacts stay closed and the guage does not move to charge, you have a problem with the generator. If things move like they should, you may be able to adjust the field circuit solonoid in the reg or maybe the reg isn't grounded or maybe the reg is shot. I too am in Southwest Michigan Stan, feel free to give me a call.
Curt Cooke
Hudsonville, MI
616-669-0486
Post a Followup
: Re: Re: Super A Charging System
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
