Re: Zenith Carb venturi question
Posted by Bob M on December 02, 2004 at 06:12:56 from (151.190.254.106):
In Reply to: Zenith Carb venturi question posted by Bobcat on December 01, 2004 at 19:08:29:
Presuming everything else is set right (spark and cam timing, valve clearances, etc), sounds like it’s a chronic lean condition at idle. Most likely cause is a vacuum leak - ie. intake manifold to head, carb to manifold, worn carb throttle shaft bushings, etc. To find the leak, with the engine idling and the choke full open spray WD-40 or play gas from an unlit propane torch on the suspect areas. The idle smooth out and speed will increase when the WD-40 or propane gets sucked into the leak. If the above doesn’t do it, the carb idle mixture is chronically lean. If you slowly pull the choke with the engine warm and idling and find a choke setting where the idle smooths out, that’s the problem. You’ll then need to go back inside the carb and look for a partial blockage in the idle circuit, a wrong (too small) orifice someplace, a crack in a casting (unlikely), etc. Good luck! Cause for a problem like this can sometimes be tough to locate…
Home
| Forums
Today's Featured Article -
Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
