Re: Not Cold enough, Not windy enough
Posted by Need Expert Advice Here.. on December 02, 2004 at 21:19:28 from (209.180.79.76):
In Reply to: Re: Not Cold enough, Not windy enough posted by MeAnthony on December 02, 2004 at 20:36:23:
Good question...and I'm not the person to be asking. I do remember a fellow pulling a 8 footer with a WD9 without any problem. I'm just guessing that it would be almost too much to expect from an "M". But, I'm usually wrong, so let's hope someone with experience will answer.
Rauville
Post a Followup
Subject:
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
