Re: Not Cold enough, Not windy enough
Posted by captaink on December 03, 2004 at 07:52:39 from (66.115.214.56):
In Reply to: Re: Not Cold enough, Not windy enough posted by Need Expert Advice Here.. on December 02, 2004 at 21:19:28:
In SE South Dakota the rule of thumb is 10 Hp for each point, however I did pull 13 points behind my 966 in L3, but it was really too much for it, 11 would have been better.
Hope this helps.
Post a Followup
Subject:
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
