Re: 1951 Farmall H Transmission Noise.
Posted by ChadS on December 07, 2004 at 16:42:34 from (66.228.96.214):
In Reply to: 1951 Farmall H Transmission Noise. posted by farmallhal on December 07, 2004 at 16:31:13:
Remove the belt pulley, or the plate where it would be,, and have a look at the shaft, if that bearing is out,, you should be able to move it and see if that is what it is. H's are famous for breaking the bearing castings off the differential housing. the brake pinion shaft holds it up,, but it will rub, and grind in there, kinda sounds like a slight clunk when the tractor first takes off, or the brakes applied, it can also sound like a lite gear grind sound too. it will also act like the brakes are on for a split second till it moves,,,, if you have problems getting it into gear, or sticking in 2 gears,, you may have the pilot bearing in the top shaft out,, it would make a real bad clunking if that was out, from the shaft wobbling up and down and not allowing the gears to properly mesh. Hope this helps a bit,, torn quite a few H trannys up and rebuilt them, thats what ive always heard when they break,, ChadS
Home
| Forums
Today's Featured Article -
Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
