Diagnosing my electronics baby steps.
Posted by Tanner Clark on December 20, 2004 at 04:17:21 from (206.239.4.3):
Ok this weekend was a little productive. Anyway, I was able to spend a couple of hours work on the tractor Saturday afternoon. I have that nice multi tester but the truth is, is that the little pigtail light is still way more important in figuring out where current is or is not going. Ok, I bought a new ignition switch and starter switch. I have good power through the 12 volt coil to the negative side, however once I connect the negative side to the Dist. there is no power on the negative side. I believe this is because the points are closed and until they are open no power will be going through the Dist. Is this correct? So now that I think I have worked out the electronics of this thing, I am feeling a little better, "baby steps". I went to use the hand crank to figure out TDC for the #1 piston and the little pin is missing on the outside of the cranking bar. So I had no way of really using the hand crank to get this in time with the dist, what type of pins have you guys put in there to replace the stock pin? Also, you are supposed to set the points to 0.020 when one of the rectangle shaft corners (not the flat side) is pushing the arm out, just at the point of where it should open and shut. I have done this, but I have noticed that only one corner of the shaft touches the arm, or in other words the points are only opening once per full revolution of the Dist. Shaft. I have a feeling this is incorrect and that the points should be opening 4 times per revolution. So once I figure this out I will proceed with TDC and the plugs.
Home
| Forums
Today's Featured Article -
Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
