Re: hydralic lift
Posted by darin on December 22, 2004 at 18:29:06 from (69.40.62.199):
In Reply to: Re: hydralic lift posted by iester on December 22, 2004 at 17:32:20:
you should do a pressure check on the system first then you can check the screen where the lines go into the resivoir ,may be plugged.hy tran fluid has a waxy content that can cause a build up there.also pressure regulator valve or safty valve or aweak pump.
Post a Followup
Subject:
