Re: Setting timing correctly on my 44 H
Posted by El Toro on December 31, 2004 at 15:31:51 from (172.168.195.92):
In Reply to: Setting timing correctly on my 44 H posted by tanner clark on December 31, 2004 at 14:13:07:
Hi Tanner, Why don't you use a timing light. Mark the knotch or groove on the pulley with a piece of chalk. Hook the timing light to the battery posts and the other lead to No1 sparkplug
that is closest to the radiator. My light is the inductive type that you just clip over the sparkplug wire. You may have a use piece of copper tubing to slide over the end of plug and hook the plug wire to the tubing, then hook timing light to tubing too. Run engine at an idle and switch on timing light. The light should blink every time the engine fires on No1. Note where chalk is on damper pulley. Should be close to pointer. You move distributor gently until both marks are aligned. Easier if you have a helper. Loosen distr. just enough so it can be
rotated if needed. Retighten when timing is set.
Hal
Post a Followup
Subject:
Today's Featured Article - Farmall 460: That's My Girl - by LeAnn R. Ralph. How many sounds can you think of that are as familiar to you as your own breathing? What about the hum of your refrigerator? Or the thump of your clothes dryer? Maybe the engine of your car? You hear those sounds every day, and you don't think much about them, do you. I can think of a few common, ordinary sounds in my daily life, too. ... [Read Article]
