Re: No fuel coming from pump.
Posted by Farmer Bob on January 08, 2005 at 15:20:12 from (64.113.14.154):
In Reply to: No fuel coming from pump. posted by Davis D. on January 08, 2005 at 14:40:37:
Davis D., Had the same problem with the RM pump on my 340D and I think they are the same pump. Had the pump professionally rebuilt and still ended up having a friend help as we lightly pressurized the fuel tank to "help the fuel" through the pump. We cracked the lines at the injectors starting with the center two, then the other two one at a time. Would get just a little fuel and some air out of the lines each time this was done. Finally, after about 2 hours of work, got the fuel to "spurt out of the lines with them completely out of the injector fittings. As this was done on each line I tightened up that line and went to the next one. One help might be to put a charger on your battery while doing all the cranking or even another vehicle with jumper cables. Either was, becareful not to smoke your starter. Turn it over no more than 5-7 seconds with each try and let the starter cool off some between turns. We finally got it bled. The Roosa's are stubborn to bleed without a primer aparatus like the 560's had. They do not like any air in the system.
Home
| Forums
Today's Featured Article -
Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
