No fuel coming from pump.
Posted by Davis D. on January 08, 2005 at 14:40:37 from (64.12.117.13):
I am trying to start my IH 504D after a rebuild. 2-3 gal.s of fuel is in the tank. The fuel has been bled through the injector pump. The fuel did not "flow" through the pump. I had to turn the engine over to get the fuel through it. I tried several times cranking it to get the fuel to the injectors. Each time I cranked until the battery went down. I disconnected an injector line from the pump and turned it over but no fuel came out. The pump is a Roosa Master. I know it takes awhile to bleed the fuel to the injectors but this seems way too long. I worked on it 2 hours. Any ideas.
Post a Followup
Subject:
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
