Re: Stuck Cranking Shaft on Farmall H M
Posted by CNKS on January 08, 2005 at 18:07:48 from (204.249.178.138):
In Reply to: Stuck Cranking Shaft on Farmall H M posted by Wayne M. Smith on January 08, 2005 at 17:57:06:
You might try repeated applications of a penetrant such as PB Blaster, or you might have to pull the front bolster off. I suppose you could heat the area around it, but if it is rusted really good, about the only way to get it to work like new is disassembly.
Post a Followup
Subject:
