Re: No fuel coming from pump.
Posted by TDK on January 08, 2005 at 19:50:06 from (152.163.101.13):
In Reply to: No fuel coming from pump. posted by Davis D. on January 08, 2005 at 14:40:37:
Had the same problem with a R/M pump on a Ford a while ago. Loosen the screws on the timing cover on the pump or remove cover altogether. If no fuel runs out, then turn engine over till it does. Replace cover and try bleeding injectors again. Worked for me, after trying for two hours!
Post a Followup
Subject:
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
