Re: More crank bearings
Posted by lee on January 12, 2005 at 15:50:31 from (24.24.95.246):
In Reply to: Re: More crank bearings posted by CNKS on January 12, 2005 at 14:47:03:
Sounds like you will assemble with engine out of tractor and crank case up. Don't put the rear rope seal or any other seals in. This is a mock up to check mains clearance using plastigage. Keep things clean. Clean all the mains bearing saddles. Lightly oil. Place the bearing shells lightly oiled. Place the crank lightly oiled. Place the bearing shells in the caps lightly oiled. Oil the bolts. Bolt the caps on without plastigage and torque to spec to seat the bearing shells. Turn the crank over a little it should be free. Remove the mains caps. Wipe the exposed crank journals and cap bearing surface clean of oil. Use thinner or alcohol to remove all oil. Place the plastigage per instructions on package. Place the caps and torque to specs. Don't turn the crank. Remove the caps. Check the plastigage clearance. The plastigage will likely stick to surfaces. It doesn't need to be cleaned off completely. It will dissolve in oil. The clearance spec is the total clearance with the crank bottomed in the mains saddles. Lots of guys would just assume the shop did their job correctly but I would do this plastigage check. It's a bit of work but worth knowing you got what you paid for, proper bearing clearance. If this were done from underneath the tractor the crank must be forced up and held up in the saddles. The same can be done on the rods. Torque the rod bolts carefully so as not to crush the plastigage artificially.
Home
| Forums
Today's Featured Article -
Timing Your Magneto Ignition Tractor - by Chris Pratt. If you have done major engine work or restored your tractor, chances are you removed the magneto and spark plug wires and eventually reached the point where you had to put it all back together and make it run. On our first cosmetic restoration, not having a manual, we carefully marked the wires, taped the magneto in the position it came off, and were careful not to turn the engine over while we had these components off. We thought we could get by with this since the engine ran perfectly and would not need any internal work. After the cleanup and painting was done, we began reassembly and finally came to t
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
