Re: Super A touch control rebuild followup questi
Posted by scotty on January 13, 2005 at 08:17:24 from (199.231.49.128):
In Reply to: Super A touch control rebuild followup questions posted by scott#2 on January 13, 2005 at 08:04:41:
scott,
# 1 When I rebuilt mine I had the tan o-rings left over as I recall.
#2 If the bores are smooth and the bore size is uniform I wouldnt do anything.
#3 I used the permatex sealant in the can with the brush applicator on the bottom plate and the front cylinder head, just allow it to get tacky before reassambly.
#4 After I had torn the whole unit down, I brought the block into work and let it sit in the cleaning tank for a day and then blew out all the passage ways with high pressure. This also loosened all the old gasket material so that it was easy to clean off.
scotty
Post a Followup
Subject:
