Re: IH 606 gets stuck in gear
Posted by PAULIH300 on January 20, 2005 at 17:53:59 from (64.12.117.13):
In Reply to: Re: IH 606 gets stuck in gear posted by the tractor vet on January 19, 2005 at 19:18:43:
My 300U sorta does the same thing.You can go forward into a snowbank and work the bucket,but sometimes when you go to back up its like the clutch isnt fully releasing....the shifter fights moving out of 1st.It takes 2 hands to get it into reverse (sometimes).If I remove the shifter to look at it,and its in neutral,will I have any problem putting it back in? (assuming I will have to weld the worn areas back up).
Post a Followup
Hide: Yes No
Hiding your address protects you from spam generators but allows you to receive email response notifications.
Subject: 65534p> :
