Re: Possible to use a Case 580CK hoe on an H?
Posted by Dave in CT on January 21, 2005 at 14:53:04 from (204.60.63.236):
In Reply to: Possible to use a Case 580CK hoe on an H? posted by Dave in CT on January 21, 2005 at 09:11:19:
I'll have a JD #45 loader on the front which, admittedly, is a bit light for the task - 585 lbs. If I could add the needed weight to the front via weights, rock box, block in the loader, would it then be workable or am I in danger of breaking the tractor because of all the weight on both ends? TIA
Post a Followup
Hide: Yes No
Hiding your address protects you from spam generators but allows you to receive email response notifications.
Subject: 65534p> :
