Re: Farmall 560 Starter Keeps Running
Posted by JOSSETTE on February 05, 2005 at 14:06:56 from (216.114.221.58):
In Reply to: Farmall 560 Starter Keeps Running posted by Old_Farmall_560 on February 05, 2005 at 13:52:49:
if there is a solonoid on the starter i would start there. if not the button is probably sticking by magnetic force and it goes back when the field is cancelled. turn switch on and jump the starter at the relay. if the starter stops after starting the button is faulty. if the starter keeps going you might have a weak or damaged drive and it is hanging up on the flywheel. it just might need a shim to help it come back. make sure the ground cable is good and secure!!!!
Post a Followup
Hide: Yes No
Hiding your address protects you from spam generators but allows you to receive email response notifications.
Subject: :
