Re: Farmall 560 Starter Keeps Running
Posted by Old_Farmall_560 on February 07, 2005 at 12:20:40 from (216.167.149.166):
In Reply to: Re: Farmall 560 Starter Keeps Running posted by JOSSETTE on February 05, 2005 at 14:06:56:
I looked at the starter a bit more this morning and here's more information.
The problem of course is that with the key on, the starter will engage the engine normally but will not stop when the button is released.
With the key off or on, and when the starter is "jumped" with a screwdriver at the solenoid, the starter spins but does not engage the engine. When jumper is removed, starter ceases to spin.
With the key on, but with push-button start switch not depressed, there is a small amount of voltage (checked with a test light) at the solenoid on the "R" terminal but nothing on the "S" terminal. With key off, no voltage is detected at either terminal.
I have not moved any wires since reinstalling a rebuilt starter several months ago and have started the tractor numerous times since then. This problem started after reinstalling a reworked head and after attempting to start the tractor several times. At first, the starter would shut off normally when the push button starter switch was released, then after a few tries, the problem of the starter continuing to run started.
Post a Followup
Hide: Yes No
Hiding your address protects you from spam generators but allows you to receive email response notifications.
Subject: :
