Re: Piston rod bearings on a Farmall A C113 engine
Posted by riverbend on February 19, 2005 at 06:51:00 from (208.160.33.199):
In Reply to: Re: Piston rod bearings on a Farmall A C113 engine posted by MACE on February 19, 2005 at 06:03:54:
You can check the crank and bearing clearence with plastigage. If the clearence checks out, and the crank and shells are really 'like new', it should be fine the way it is. Be sure to keep everything spotless - just like you were putting the engine together for real.
If you use new bearings, you will have to plastigage them too. Check with your local IH dealer for +0.030" bearings. They should be easy to find.
Post a Followup
Hide: Yes No
Hiding your address protects you from spam generators but allows you to receive email response notifications.
Subject: :
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
