Re: Ih 350 Utility tractor (56-58) How rare?
Posted by PAULIH300 on February 22, 2005 at 17:26:23 from (152.163.101.13):
In Reply to: Re: Ih 350 Utility tractor (56-58) How rare? posted by Dave D on February 22, 2005 at 16:19:50:
Front implements (loader) sure do their damage to the front ends on the Utes.Worn/broken steering boxes,worn tie rod ends,bent adjusting sleeves,loose splines at the steering arms,broken spindles...they are all possible thanks to heavy front loads and years of wear to these beasts of burden.IH sure should have given more thought to beefing up the fronts of what was to be ultimately very versatile machines...the lay persons economical substitute for a Payloader,or a true loader/backhoe.
Post a Followup
Hide: Yes No
Hiding your address protects you from spam generators but allows you to receive email response notifications.
Subject: :
