Re: Thompson Uni-ball governor parts
Posted by zooeyhall on February 23, 2005 at 08:37:38 from (204.26.68.3):
In Reply to: Re: Thompson Uni-ball governor parts posted by RustyFarmall on February 23, 2005 at 07:14:20:
Yes, it is the throttle shaft assembly between the governor and carburator.
It is slightly different than the original part. The Thompson gov throttle shaft has (on the governor end) a lever with a threaded hole that a ball socket is bolted to. The orignal uses a clevis arrangement.
I might see if I can get a standard throttle shaft and see if I can modify it.
Post a Followup
Hide: Yes No
Hiding your address protects you from spam generators but allows you to receive email response notifications.
Subject: :
