Farmall 706 310d antifreeze problem help please!
Posted by Trent R. Young on February 27, 2005 at 11:36:52 from (64.12.117.13):
I would very much appreciate some advice on my tractor. WEnt to change my oil for spring and i found i had a very little bit of antifreeze in the bottom of the oil pan. I left the oil out of the pan for a week. and found about a tee spoon in the pan. I remove the pan and pressure test cooling system and seen 2 drips of coolant at the bottom of the number 3 and 4 cylinder sleeves. Could not tell from piston side or outside of sleeve. Tractor has 6100 hrs and little smoke at start up then clears right up in a minute. runs great. I do not want the coolant to ruin bearings. thanks all your help is greatly appreciated Trent
Post a Followup
Hide: Yes No
Hiding your address protects you from spam generators but allows you to receive email response notifications.
Subject:
