Re: Farmall 706 310d antifreeze problem help ple
Posted by K.B.-826 on February 27, 2005 at 13:03:35 from (209.163.30.26):
In Reply to: Farmall 706 310d antifreeze problem help please! posted by Trent R. Young on February 27, 2005 at 11:36:52:
Probably leaking past the o-rings around the outside of the sleeves. That's pretty common with these older German diesels. With the amount of work involved to remove the sleeves, you're almost better off just overhauling the whole engine. Remember, it is just short of 40 years old, even if it runs great, it will run/start even better after an overhaul. Don't run it like it is, it only had a couple drips when you pressure tested it cold, but it will really start leaking when you get a full load on it.
Post a Followup
Hide: Yes No
Hiding your address protects you from spam generators but allows you to receive email response notifications.
Subject: :
