Loose distributor cap
Posted by gascolator on March 06, 2005 at 09:46:58 from (151.197.212.40):
While plowing snow the other day, number 2
cylinder on the 300U ceased to fire. Finished
a couple little things then put her away (try
that on a 2-cylinder Greenie!).
Feared the worst (stuck valve), but it was
just the worst of four fouled plugs probably
caused by a combination of cold running and
a too-rich mixture, together with oldish wires.
Swapped the plugs, replaced the wires. The
local NAPA had a cap but not a rotor, so
deferred on those two for the time being. It
was fun to change one plug and wire at a time,
start it up, and note it running a bit better
with each new plug and wire (I do one pair
at a time to know where I've introduced a
miss if I do introduce a miss in fabricating
the new wires.)
However, I did notice that the cap is a bit
loose on the distributor.
Is there supposed to be gasket between the cap
and the distributor? Or is it just that the
clips have lost their fallorum (oomph)?
If the latter case, is the solution simply to
're-arc' the spring clips, or are those
separately available?
It runs fine now, but it sure isn't right and I'm
sure it makes things more vulnerable to moisture
and to eventually just falling apart.
Post a Followup
Hide: Yes No
Hiding your address protects you from spam generators but allows you to receive email response notifications.
Subject:
Today's Featured Article - A Lifetime of David Brown - by Samuel Kennedy. I was born in 1950 and reared on my family’s 100 acre farm. It was a fairly typical Northern Ireland farm where the main enterprise was dairying but some pigs, poultry and sheep were also kept. Potatoes were grown for sale and oats were grown to be used for cattle and horse feeding. Up to about 1958 the dairy cows were fed hay with some turnips and after that grass silage was the main winter feed. That same year was the last in which flax was grown on the farm. Flax provided the fibre which w ... [Read Article]
