Re: I'm Kinda Dense: Alternators Again
Posted by Bob M on March 09, 2005 at 10:11:15 from (151.190.254.108):
In Reply to: I'm Kinda Dense: Alternators Again posted by Allan in NE on March 09, 2005 at 09:37:56:
Allan - The alternator #1 ("exciter") terminal is hot whenever the alternator is providing current. The diode is used to stop current from backflowing from the #1 terminal to the ignition coil after you open the ignition switch. Otherwise the #1 terminal backfeed will cause the engine to continue to run after you turn off the ignition.
As originally intended by the alternator designers, a small lamp is used instead of a diode. The lamp serves 2 purposes: 1) It limits the backflow current to a level below that required to fire the coil, and 2) It works as an alternator "idiot light" - it will light if the ignition is on but the alternator is not generating current.
Make sense now?
Post a Followup
Hide: Yes No
Hiding your address protects you from spam generators but allows you to receive email response notifications.
Subject: :
Today's Featured Article - Show Coverage: Fair Weather Tractor - by Dave M.. No, Fair Weather isn't some rare brand. It's the kind you can't leave out in the rain. Here's how it happened. I had been casually looking for a tractor for weeks. I saw a few 9N's, but they had even fewer amenities than the 8N my Grandpa bought new in '52 with a Dearborn loader. That was 10 years before I was born, so I grew up thinking that 8N was the world's best tractor. Grandpa had greenhouses, with over half an acre under glass, and that 8N did almost everything. It was the only ... [Read Article]
