Re: Putting the engine back together
Posted by El Toro on March 14, 2005 at 14:14:47 from (205.188.117.73):
In Reply to: Putting the engine back together posted by TKN on March 14, 2005 at 11:05:55:
I would use a glaze breaker in the sleeves using a drill motor. Coat the the glaze breaker with lots of oil, then thoroughly clean the sleeves.
I would use warm soapy water to do this cleaning and then dry each sleeve and coat with engine oil. Clean the crankshaft too and coat with engine oil.
You should use a new paint brush to coat all of the engine parts prior to assembly. That includes bearings, pistons and sleeves. Those seals at the bottom of the sleeves can cause leakage into the crankcase. I would fill that block with water high enough to cover the seals
on the sleeves and check for leaks before assembling the engine. The oil pump should be primed with fresh engine oil too. Hal
Post a Followup
Hide: Yes No
Hiding your address protects you from spam generators but allows you to receive email response notifications.
Subject: :
