Re: H, Engine RPM under load low
Posted by RustyFarmall on March 19, 2005 at 08:53:28 from (199.120.81.212):
In Reply to: H, Engine RPM under load low posted by 230,H,M on March 19, 2005 at 05:01:34:
I guess I am somewhat confused here, any dyno I have ever been around would kill an engine if you cranked it down enough. The proper procedure for using a dyno is to open the throttle on the tractor, and then start cranking the wheel on the dyno until you are reading 540 pto rpms. At that point you take a horsepower reading. The actual speed of the tractor engine is irrelevant.
You only have a problem if the observed horsepower at 540 rpm is lower than expected.
Does this help? Am I totally off base?
Post a Followup
Hide: Yes No
Hiding your address protects you from spam generators but allows you to receive email response notifications.
Subject: :
