Re: Uh-Oh!!!!
Posted by Dave_Id on March 22, 2005 at 09:07:17 from (66.82.9.83):
In Reply to: Uh-Oh!!!! posted by Dixieland on March 22, 2005 at 08:57:54:
It sure sounds like it. Make sure when you start timing it, you have #1 cylinder at the compression cycle. Take out spark plug, and hand crank until the compression pushes your finger out of plug hole. At this point you can check to make sure rotor is pointed at #1 on your distributer cap.... note rotation of rotor, and double check to make sure wires are plugged in correctly. I'm guessing you may have installed mag 180 degrees off.
Post a Followup
Hide: Yes No
Hiding your address protects you from spam generators but allows you to receive email response notifications.
Subject: :
