Re: pit falls on rebuilding super M
Posted by MAGMAN on March 24, 2005 at 06:04:44 from (152.163.101.13):
In Reply to: Re: pit falls on rebuilding super M posted by jnewark on March 24, 2005 at 05:24:22:
Dont be afraid to rince out the motor with hot soapy water if you think theres any particles that should not be there any where. Also this is what I always do I take a piece of hose like gas line and I cut little pieces about an inch long and slide them up on the rod bolts so when your trying to get the piston in from the top they dont go down and nick a rod journel.VERY IMPORTANT or make sure you have enough soft clean rags over the crank when you do it. Put a very very light oil on the out side of the sleeves just so they basicly dont rust in and slide if you put to much its going to be to thick and you will have a hard time getting sleeves in. If you get a sleeve hung up almost in you can go to your freezer or buy a bag of ice and stick it in the cyl good and tight and wait awhile it will shrink the sleeve enough to start moving again usally.If you broke any of the bent washer things on the rod caps they cost about ten bucks a piece to replace at the dealer.I use spray gasket adheasve from Napa to spray the head gasket with its red and made by them or forma gasket .Thats about all I think of.Hope this helps and if you already knew all this SORRY alot of folks dont. MagMan
Home
| Forums
Today's Featured Article -
Tractor Profile: Farmall M - by Staff. H so that mountable implements were interchaneable. The Farmall M was most popular with large-acreage row-crop farmers. It was powered by either a high-compression gas engine or a distillate version with lower compression. Options included the Lift-All hydraulic system, a belt pulley, PTO, rubber tires, starter, lights and a swinging drawbar. It could be ordered in the high-crop, wide-front or tricycle configurations. The high-crop version was called a Model MV.
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
