Re: pit falls on rebuilding super M
Posted by jnewark on March 24, 2005 at 06:34:24 from (167.21.1.227):
In Reply to: Re: pit falls on rebuilding super M posted by MAGMAN on March 24, 2005 at 06:04:44:
thanks for the reply, I figure any refresher is good. I didn't know about covering the rod bolts,.The Ice reminded me when I was 16 I worked on putting sleves in a Massey Harris, we packed them full of dry ice, slid in like a champ. Will I need to use plastigage on the journals? do I need to check ring end gap, and side clearance? or will everything be within tolerances?
thanks in advance
jack
Post a Followup
Hide: Yes No
Hiding your address protects you from spam generators but allows you to receive email response notifications.
Subject: :
