Farmall Tractors Discussion Board
Re: Re: WIDE narrow
Posted by MrGadget on December 06, 1999 at 06:32:54 from (216.170.12.242):
In Reply to: Re: WIDE narrow posted by Johnny Angel on December 05, 1999 at 05:03:42:
A loss of balance situation occurs anytime the vertical line from the point of CG perpendicular to the level plane moves past the imaginary line of support. That line of support is the line drawn from the point of contact of the rear tire to the ground, to the point of contact of the front tire.
With a tricycle front end, that area of stability is a trainagle and it is smaller than the area of stability with a wide front, which is a square. As long as that vertical line from your CG to the ground stays within that area of stability, your OK, get it outside that area, and you're on your side.
Which would you rather talk a wild ride downhill on...a tricycle or a coaster wagon? Any 5 year old can answer that one for you.
Post A Followup
: Re: Re: Re: WIDE narrow
