Gas Gauge
Posted by chadd on April 05, 2005 at 10:03:10 from (155.92.30.54):
On our 966, the fuel tank overflowed when we filled it up and the fuel gauge quit working soon after. It is really weird. When you turn the key, the needle moves up a little bit, and when you hit a big bump, it will bounce. However, it refuses to show the level in the tank. Is the ground bad or something? Any help would be appreciated.
Post a Followup
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
