Re: Gas Gauge
Posted by Allan in NE on April 05, 2005 at 12:34:50 from (148.78.243.26):
In Reply to: Gas Gauge posted by chadd on April 05, 2005 at 10:03:10:
Chadd,
Run a ground wire jumper to the SENDER SIDE of your gauge. That should force it to read full.
If it does, you've got a bad wire, connection or sender.
If it does not, you've got a bad gauge. (Problem is usually in the sender side, however).
Allan
Post a Followup
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
