Re: Axle ratios, etc
Posted by Bob on April 26, 2005 at 15:57:46 from (66.163.134.177):
In Reply to: Axle ratios, etc posted by CNKS on April 26, 2005 at 13:54:15:
As far as the tranny temp goes, that can be solved with a monster tranny cooler. Some people also swear by a deep, finned aluminum tranny pan.
For occasional towing, you'll never get back the cost of the gear change.
Also, with changing the gears, there's a bit of technical knowledge and labor involved, and for best results, some special gauges are needed to set up the gears, especially in the IFS axle.
If you're really intent on changing the gears, the ideal thing would be a swap of axles with someone wanting to go the other way..
Also, the engine computer may be happier with a different chip, if the axle ratio is changed.
The speedometer will be "off", I forget the details of correcting that, it will probably require a DRAC module.
So for occasional towing, adding a big cooler is a great idea, and changing the axle ratio is a somewhat difficult, costly option that will take a very long time to pay back.
Post a Followup
Today's Featured Article - The Fordson F Ignition System - by Anthony West. A fellow restorer contacted me earlier this year asking for some help and advice on a model F that he was restoring. He had over a period of months spent a fair amount of his hard earned cash on replacement parts for the old "trembler" ignition. Sadly though all his efforts seemed to be a waste of time and money as he still couldn''t get the temperamental old thing to run correctly!! If i said that this was a little frustrating for him that would be "conservative" in fact the problem had reduce ... [Read Article]
