Axle ratios, etc
Posted by CNKS on April 26, 2005 at 13:54:15 from (204.249.178.138):
In 1992 I bought a GMC K1500, 350 cu in, automatic, 3.42 rear axle. Since then I have developed tractor disease and tow occasionally. My half ton is not a towing vehicle. I have added an extra capacity trans oil pan and an external trans oil cooler. Oil temp hits 230-250 degrees even in "flat" Kansas because of the usual head or cross wind. Pickup has 83000 miles (just broken in) and is in excellent condition, inside and out. A $30000 3/4 ton (including trade, rebate and sales tax, GMC 2500HD 6.0, 4.10) is not an option because I only tow once a year or so for any distance. Transmission is a 4L60 (700R4), the small one. Towing "capacity" is about 6500 lbs, meaning on flat ground with a tailwind -- that situation never happens. The trans will overheat against the wind even when towing a Farmall C, less than 5000 lbs including the trailer. Does anyone have this combination with a 3.73 or 4.10 axle ratio, and will this allow me to do my occasional towing without eventually melting my transmission? Lower gears (high numerical) would also help unloaded travel, as the lockup disengages on the slightest incline. The thing is simply geared too high--I am somewhat hesitant to go to 4.10, as I would need that gearing only for towing. Empty in overdrive it turns about 1800 rpm at 70 mph, with a 4.10 that would be about 2200 rpm -- perhaps that's not too bad, still lower than the rpm before overdrive became common. I don't know how much the 3.73 ratio will help. Would have to do both axles -- read on one of the towing forums that it would cost about $1500 for both axles, so it needs to work. There are also underdrive/overdrive split range (2 speed axle) attachments, more like $3000 for those. I realize I can't make a 3/4 HD out of it, just want something that will work for occasional towing, within the rated specs. All comments except--buy another pickup--are welcome.
Post a Followup
