Re: Axle ratios, etc
Posted by K.B.-826 on April 26, 2005 at 20:51:27 from (71.10.89.78):
In Reply to: Axle ratios, etc posted by CNKS on April 26, 2005 at 13:54:15:
CNKS, I know you don't want to hear it, but for the $ you'd spend modifying your pickup, you could probably just go out and buy an old 3/4 ton reliable enough for occasional towing. I know, insurance... but it probably won't cost you any more in the long run, considering what you'd spend on gas with 4.10's in the rear of your daily driver.
Post a Followup
