Re: S M 12 VOLT SYSTEM
Posted by Bob on April 28, 2005 at 11:07:35 from (66.163.134.177):
In Reply to: S M 12 VOLT SYSTEM posted by CLAYTON on April 28, 2005 at 09:55:45:
You can get a "side marker light", with a #194 bulb in it, and wire it in series with the wire to the #1 terminal on the alternator. You can hide it under the hood, out of sight, if you want. The filament resistance of this bulb will limit the backfeed of current to a level that will not operate the ignition, so the tractor will shut off, as it's supposed to. The original design of this alternator was for use with an "idiot light" that serves the same function in the excite circuit. If you want use a diode, go to a place like Radio Shack, and get a 2.5 Amp 1000 PIV diode, and connect it into the excite line. (Will cost between $.50 and $2.00.) This diode will be a little black plastic cylinder, with a white band at one end. The white band is the CATHODE, and the lead from this end of the diode goes TO the #1 alternator terminal. By the specs of this diode, it should be more than adequate, but after an odd failure or two, for years, I have used two of them in parallel. Put them side by side, with the white bands at them same end, twist the leads together, connect them into the "excite" wire with a couple of crimp "butt" connectors, on cover with a length of heat shrink. I've had NO failures using this method. Also, a local automotive electrical shop should have available a connector that fits the alternator with pigtails attached, with the diode already in place, just for these conversions.
Home
| Forums
Today's Featured Article -
Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
